Geeetech A10 ignoring temperature settings
SanahGrat
Post by SanahGrat »
Hi all
I'm new to 3D printing and I recently got a Geeetech A10. It seems to be working very well aside from one thing.
I'm getting a lot of stringing, and the print sticks to the bed a little too well (tricky to remove after printing). I tried to lower the temperature of both the hot end and the bed in Cura, but it seems the printer just ignores it and always prints at 215C on the hot end and 60C on the bed. The weird thing is that it heats to 190C first when you select "Preheat PLA". I'm using Cura if it makes a difference.https://omegle.onl/ vshare
JustinSEO
Re: Geeetech A10 ignoring temperature settings
Post by JustinSEO »
Go to the start G-Code under Machine Settings and remove the portion where it sets the temperature to 215 and the bed to 55. I had the same issue when using Cura for the first time with this printer. Someone modified the start G-Code to have pre-set temperatures.
