[PROBLEM] Cannot connect only to Repetier host
pedracinI.julien@gmail.com
Post by pedracinI.julien@gmail.com »
Hello, happy buyer of an A20T, I cannot connect to my computer from Repetier. The printer constantly reboots.
I tried through the Arduino monitor, the printer works normally when entering commands, also with Ultimake Cura software. I specify that I am in baud 250000, the drivers well installed otherwise I could not use other software with. I also installed Marlin 2.0 but it doesn't change anything if I reinstall the original Firmware provided by Geeetech. I also tested on another PC with an old version of Repetier, without change.. I'm out of ideas.
here is a copy of the log:
Code: Select all
02:42:55.774 : start
02:42:55.774 : Marlin bugfix-2.0.x
02:42:55.774 : echo: Last Updated: 2021-09-26 | Author: (none, default config)
02:42:55.774 : echo: Compiled: Sep 29 2021
02:42:55.774 : echo: Free Memory: 1832  PlannerBufferBytes: 1776
02:42:57.094 : echo:V85 stored settings retrieved (634 bytes; crc 44948)
02:43:01.608 : echo:SD card ok
02:43:01.608 : FIRMWARE_NAME:Marlin bugfix-2.0.x (Sep 29 2021 02:28:28) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Geeetech A20T EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
02:43:01.608 : Cap:SERIAL_XON_XOFF:0
02:43:01.608 : Cap:BINARY_FILE_TRANSFER:0
02:43:01.624 : Cap:EEPROM:1
02:43:01.624 : Cap:VOLUMETRIC:1
02:43:01.624 : Cap:AUTOREPORT_POS:0
02:43:01.624 : Cap:AUTOREPORT_TEMP:1
02:43:01.624 : Cap:PROGRESS:0
02:43:01.624 : Cap:PRINT_JOB:1
02:43:01.624 : Cap:AUTOLEVEL:1
02:43:01.624 : Cap:RUNOUT:1
02:43:01.624 : Cap:Z_PROBE:1
02:43:01.624 : Cap:LEVELING_DATA:1
02:43:01.624 : Cap:BUILD_PERCENT:0
02:43:01.624 : Cap:SOFTWARE_POWER:0
02:43:01.624 : Cap:TOGGLE_LIGHTS:0
02:43:01.624 : Cap:CASE_LIGHT_BRIGHTNESS:0
02:43:01.624 : Cap:EMERGENCY_PARSER:0
02:43:01.624 : Cap:HOST_ACTION_COMMANDS:0
02:43:01.624 : Cap:PROMPT_SUPPORT:0
02:43:01.624 : Cap:SDCARD:1
02:43:01.624 : Cap:REPEAT:0
02:43:01.624 : Cap:SD_WRITE:1
02:43:01.624 : Cap:AUTOREPORT_SD_STATUS:0
02:43:01.639 : Cap:LONG_FILENAME:0
02:43:01.639 : Cap:THERMAL_PROTECTION:1
02:43:01.639 : Cap:MOTION_MODES:0
02:43:01.639 : Cap:ARCS:1
02:43:01.639 : Cap:BABYSTEPPING:1
02:43:01.639 : Cap:CHAMBER_TEMPERATURE:0
02:43:01.639 : Cap:COOLER_TEMPERATURE:0
02:43:01.639 : Cap:MEATPACK:0
02:43:01.646 : X:-5.00 Y:0.00 Z:0.00 E:0.00 Count X:-400 Y:0 Z:0
02:43:01.646 : echo:DEBUG:INFO,ERRORS
02:43:01.646 : Begin file list
02:43:01.646 : A20T/A10TA2~1.GCO 1107216
02:43:01.662 : A20T/A20T-CAT.GCO 34470210
02:43:01.746 : A20T/2EB43~1.SLI/27D93~1.USB/FT232/LINUX/USBDRI~1/LIBFTD~1.GZ 3758080
02:43:01.762 : A20T/2EB43~1.SLI/27D93~1.USB/FT232/LINUX/USBDRI~1/LIBFTD~2.GZ 3573760
Maybe someone will have encountered the same problem as me, thank you in advance for helping me.
Re: [PROBLEM] Cannot connect only to Repetier host
Hello, Problem solved after two hard days.
In fact, all you have to do is remove the microSD card from the printer. Strange. If it can help other people.
