I have bought a prusa i3 from a freind who has moved onto bigger and "better" things. I have got it mounted to a board to keep it rigid and square and set it up to the point where it is printing.
I am having issues with PLA curling on the bottom layer especially but also higher up sometimes. I am running 190degrees at the nozzle and 60 degrees at the bed. Is that in the ballpark?
The bed material is currently a thin 1.5mm sheet of aluminuim which seems to have bowed/warped in the middle which probably isnt helping. Would i be better off with a thicker sheet of aluminuim or is glass the way to go? Want to get it printing as near perfect as poss on PLA before i worry about other materials.
Also i have with it a printed cone that looks like its for cooling the print with a fan ashowbox speed test
ttached but i need to get a cooling fan, what type would i need? Would this help with layer adhesion and bridging etc?
I dont even know what firmware is on it, is there a way to find out and update it?
Oh reprap gods please help me!
Prusa i3 questions
aryankanse6
Return to “Geeetech I3 Aluminum Pro”
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
