I had problem with printer that I bought 2 weeks ago, basically it stops to extrude mid-print (sometimes after few minutes, sometimes after 1h) and it doesn't go back to extruding.
I've tried multiple things:
* different print temperatures (200-215C for PLA)
* cleaning shaft and nozzle
* using different nozzle
* using different retraction distance and speed (not turned off retraction completely to rule out that retraction is the issue)
* using different firmware (Marlin 1 from webpage, Marlin 2 from github)
* using different PLAs
* trying to print different models
* adjusting tension of spring in extruder
* changing extruder fan
* using different slicers (slic3r, cura)
and nothing seems to be helping
Not sure what to try next
