I have installed a new 3D Touch probe on my i3 Pro B, but it will not function correctly.
Upgrading the firmware and checking the Marlin config.h and pins.h files was straightforward enough, but I can't get past the probe self tests.
It lights up red, and I have adjusted the screw in the top so that the light is just on.
I give M280 P0 S160 command and the flashing resets, but if I give the M280 P0 S10 command, the pin goes down but it immediately starts flashing again.
I have ordered another probe from Geeetech, in case it is faulty.
Where in the documentation is any reference to a) At precisely what height should the probe be adjusted to, b)How to set up the setscrew, c) How to go about fault finding problems if they arise ? The information might exist, but I cannot find it !Also the calibration procedure is confusing"assumes" that the EEPROM has been enabled in Marlin (without saying how to check this), and then says to zero the offset with M851 Z0, but that returns an error which states that the limits are -5 to -15. Why is this ?
I have wasted days on this mostly because of the lack of suitable information (just speechless YouTube videos, which are of no help).
Assistance from anyone who has a good working knowledge of what to look for, would be hugely appreciated.
3D Touch Issues with i3 Pro B?
KemarRoach
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
