Printing not centered on Y-axis!!!
kibanjain
Post by kibanjain »
I just finished assembling my I3 Pro C and getting everything configured. When I Auto Home the printer, everything goes to the correct location, hits the limit switches and stops, so I think all my directions are set correctly. However, when I print, the X-axis moves to the center of the bed, but the Y-axis stays near the front of the bed, instead of moving to the center even though my object was centered on the bed. I've tried both Repetier and Cura, and it doesn't make a difference https://showbox.tools/. The part comes out correctly, other than being off-center. If I were to print anything larger, though, it would be a problem.
My steppers are configured as following:
#define INVERT_X_DIR true
#define INVERT_Y_DIR true
#define INVERT_Z_DIR false
Has anyone else encountered this? Any ideas would be appreciated.
