-if i push "home" button the motor round forward only one or two step then it stop.
-if I try to move the plate forward it will go without any problems but if i try to move back, it don't move.
-if i force back the plate, and than i try to move it forward or back with the pc program, it will work. but when the plate goes over the middle of the smooth rod, these problems start again.
The motor connection is ok, I checked it. I think it's not a block or problem of the pulley/belt because the motor don't try to move, simply it will not receives the command.
Thank you very much
