I have an A10M that was working fairly well. It seems every time I go to use it I have to work through some issues. So I decided after some reading to update it with the following: BL Touch sensor for auto bed leveling, a glass build plate, Capricorn Bowden tube and a dual gear extruder. I have tried updating the firmware to Marlin 2.0 which didn't work well. Then I tried going back to Marlin 1.1.18 and I cannot get this to work either. I tried using built HEX files and compiling the code myself but still no joy. I am sure this is a simple issue for someone experienced - I am lost at this point.
I am currently running Marlin 1.1.18 with a GT2560 v3.0 controller. When I try to print benchy the hot end homes and then prints a line towards the front of the build plate(as usual). This line is not straight though. It has small loops or is sqwiggly, so I know something is not right. The adhesion is also not right so I know there is a Z offset error too. I have adjusted the E steps per mm to 155 and actually measured the filament so I think this is correct.
What am I missing?
A10M New User . . . lost
Newbie A10M
Return to “Geeetech A10 Series”
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
