Best budget 3D Printer ?
OmkarSawant
Post by OmkarSawant »
Hey guys! I'm looking to purchase a budget 3D Printer but I'm new to this and need your help.
Essentially what I'll mostly be printing is magnetic connectors that require little (like 0.6 mm) holes on the top for wires to go through. So ideally I need a 3D Printer that has the necessary precision to print such small holes.
Thoughts? Recommendations?
Re: Best budget 3D Printer ?
Hi, You can choose from the official website according to your needs.
Post by _kaktus_ »
Hello OmkarSawant.
You have specific requirements. Printing with such holes requires skill and the use of a nozzle with as small a diameter as possible.
That's what I think about it. :roll:
In my model I used nozzles with a hole of 0.3mm diameter.
The printouts were correct.
Smaller nozzle hole (0,2mm) did not allow for proper printing. :?
It's possible that a special version of the filament could be used then.
clay12
Post by clay12 »
Hi OmkarSawant!
I recommend to read that helpful article. Good luck with your choice!
Jarda3d
Post by Jarda3d »
I print 0.5mm holes with A10. But you need to know how plastic do when it is layered in circle. So I use much bigger hole and then 0.5mm is printed. You should try how big hole you need in your 3D design, to be printed as 0.5mm. It depends on many factors, so you need to test it with your setup and material.
A10 Slic3r profile: here
