Klipper firmware
Matsubaa
Re: Klipper firmware
Post by Matsubaa »
I have some hardware issues to work through but I wanted to pipe up and say that I'm using the config from the first post here but had to invert every stepper direction including the extruder.
I don't know if this is just my machine being idiosyncratic or if it's the A10 generally but that was confusing.
Hi, What driver board do you use?
Can you provide more details about your question?
So that we can solve it better. :D
3DAngel
Post by 3DAngel »
I might have issue with my eye lately.... but I could not find your config anywhere...
would you be able to post it, it would help me and others.... thanks
killvearn
Post by killvearn »
3DAngel wrote: Sun Sep 08, 2019 3:32 pm I might have issue with my eye lately.... but I could not find your config anywhere...
It's on the first post.
3DAngel
Post by 3DAngel »
yes, I did find that after.. lol
getting old.
Thanks for taking the time to share!
psxsnake
Post by psxsnake »
Massimiliano wrote: Wed May 08, 2019 6:44 am
petous22 wrote: Wed Jan 30, 2019 2:21 am Thank You very much for opening my eyes. I'm modify your printer.cfg file for my A10M with BlTouch copy. Klipper is far better firmware than Marlin. My settings is in attachments for Cura and for Klipper. printerA10M.zip
Sorry for my English.
Hi.
Very useful your conf. I've used it as a base for my A20M.
Question: My LCD does not work. Of course, I'd say, since is different.
I do not find the type of LCD of the A20M, where did you find yours?
how you set bed size?
can i see your printer.cfg for A20M?
thanks
3DAngel
Post by 3DAngel »
[stepper_y]
step_pin: ar31
dir_pin: ar33
enable_pin: !ar29
step_distance: .0125
endstop_pin: ^ar26
position_endstop: 0
position_max: 200 <================ on the Stepper X and Y and Z you set up the Max position. in A20M this would be 250
homing_speed: 30
hope this help
psxsnake
Post by psxsnake »
3DAngel wrote: Sun Nov 03, 2019 2:05 am [stepper_y]
why 5 less if bed is 255?
3DAngel
Post by 3DAngel »
to be on the safe side....
I have the supre plate glass and it uses clip to hold down the glass, so the effective print area is much smaller than 250
psxsnake
Post by psxsnake »
3DAngel wrote: Tue Nov 05, 2019 1:40 pm to be on the safe side....
you are right thanks
