Prusa I3 Pro B - Problem with Y axis
Hi everyone,
I recently bought a Geeetech Prusa I3 Pro B and after some little problems I tried to make my first 3D print!
Unfortunately I encountered a problem that I cannot explain.
After some minutes from the start of the print I heard a noise and the Y axis lost its correct reference, printing the rest of the object not aligned (then I stopped the print, but probably the problem could happen again).
I attached a photo to show the problem, I hope you can help me because I really don't know how to solve it!
Thanks a lot in advance!
- IMG_5227.jpg (79.01 KiB) Viewed 25611 times
Re: Prusa I3 Pro B - Problem with Y axis
Hi,please check this link which is related to your case:https://www.geeetech.com/wiki/index.php ... salignment.
I have the same problem.
Is there a solution for this problem?
Hello.
this is called layers shifting, it can be solved successfully.
@_kaktus_ and do you have any idea how this can be solved successfully?
Hi,you can
1. check the tightness of your belt and make the appropriate adjustments;
2. Check whether the bearing and the pulley are issued, and the card can be lubricated for lubrication;
3. The printing speed is appropriately slowed down, the reference range is 30-60mm/s;
4.Driver board voltage range 0.8-1.2V
And William did it for me.
I would add one more important point. Read more of this forum.
Maybe not all the information will be useful at this stage, but nevertheless.
Have you already found a subforum for your printer model
Greetings to you, sir.
I got it. My Stepmotor Driver (a4988) was faulty.
Now my Printer works again.
Hi.
It's nice of you to tell us about the solution to your case.
