Repetier-Host setting on ABS print
Jarda3d
Re: Repetier-Host setting on ABS print
Post by Jarda3d »
Same as PLA except temperatures.
Hotend first 258, then 250 for green, yellow, white, or 245 for gray, red, blue, black
Hotbed first 110 (120 if you can), then 110
A10 Slic3r profile: here
Post by _kaktus_ »
Hello Jhonmicky.
You must be guided by the data provided by the manufacturer of the Filament you are using.
Basically I print at temperatures:
  • heated bed 90°C
  • hot end 240°C
To improve adhesion to the substrate I use Dimafix spray.
:D
My printer has no shield or heat casing. ;)
