how to add pause in to gcode
waz1642
Post by waz1642 »
I need to pause a 3d print to place a nut in to the print
what is the best way of pausing the print
The file I'm using is https://www.thingiverse.com/thing:3202223
Wayne
Geeetech A30
Re: how to add pause in to gcode
:D Hi,You can use the LCD screen to pause printing.
waz1642
Post by waz1642 »
Thank but..
Using the pause on the LCD is not the best as I will have to be in the room at the time that is needs to be pause
Wayne
Geeetech A30
waz1642
Post by waz1642 »
Hi I have found out how to pause with Cura
https://all3dp.com/2/cura-pause-at-height-how-to-do-it/
Geeetech A30
Post by _kaktus_ »
Hello.
You can use the standard G4 command. However, I don't know if your printer's firmware supports it. Perform tests.
