auto home causes chattering
pawa10m
Post by pawa10m »
Whenever you "auto home" the hot end chatters in the bottom left corner. cannot proceed. cannot print, please advise fix.[ This is a new A10M
Jarda3d
Re: auto home causes chattering
Post by Jarda3d »
Z axis switch have bad contact. DIsconnect&connect it few times to get out oxides from contacts.
A10 Slic3r profile: here
pawa10m
Post by pawa10m »
Upon disconnecting the Z stop wiring I found the harness disconnected from the motherboard! How do I repair this? The third screw is under the carriage.
