Hi, just built I30 following instructions carefully - 10 hours!!! however, I have just tried to use the printer and tested all parts but the X motor doesn't function at all and the z motor keeps jerking and jarring not moving smoothly. Any tips.
I tried to change the x axis to seconded extruded motor, but have failed spectacularly in working out which settings to even change.
Any advice, particularly for x issue would be fantastic.
Board failure on x axis and z axis sticking
Re: Board failure on x axis and z axis sticking
2. If the x-axis motor cannot move, you can exchange the normally-moving motor end wiring with the x-axis motor wire;
3. You can check whether the z-axis threaded rod is bent;
4. You can check whether the brass nut is too tight and can be adjusted appropriately;
5. Is the coupling installed correctly?
6. Whether the left and right z-axis are at the same horizontal line.
