I wanted to mix a simplify3d renderred model with the Geeetech mixing software.
I managed this some months ago where it worked fine,
but now every time I want to mix the imported file, the program crashes at 30%.
I tried redownloading also run as admin and with windows compatibility modes, all of them.
Are there bugfixes for this?
Sourcecode?
Or any other, similar software?
Thanks a lot
Color mixing software crashes at 30%
Re: Color mixing software crashes at 30%
Hi,If you use the software, you need to make sure that the Z hop and Vase mode are turned off when slicing, otherwise the gcode imported into the color mixer after slicing may cause gcode errors and mixing failure.
Geeecube_1_0
Sorry William, but this doesnt help.
I disabled vase mode and z hop, also I tried the exact same gcode file I used in May 2019, at that time it worked perfectly.
Any other ideas maybe?
Geeecube_1_0
maybe someone has the sourcecode?
Geeecube_1_0
Last try, someone knows a workaround?
If no answer I will need to code a new app for this task, please help
Hey.
Did someone found a fix for the crashing at 30%??
I can't understand why build a printer with this funcktion and then not support it with software
