A10M stops mid-print, display is iluminated and everything flashes
SackofFluor
Hello Everybody,
I have a problem with my A10M Printer.
Lately he just sops mid-print, 3 days ago it stopped sometimes at night, two days ago after around 4h, no it cant even finish the first two layers.
The Printer just stops in place. every light (endstops, Autolevel-probe and Display) start flashing. On the Display there is nothing to see, besides flashing.
Initially i though it was because of some overheating problem, so i tried to cool the board section down, replaced the fan. Then i read that it could be that the Hot-End overheats, so i replaced the E1 fan as well, it just doesnt improve...
Does anybody has an idea how i can improve my troubleshooting or what could be the problem ?
Sincerely
Max
Sincerely
Max
Re: A10M stops mid-print, display is iluminated and everything flashes
Determine if there is a problem with the motherboard
SackofFluor
Hi William,
I only print with it connected to the PC.
Just today i tried it via SD ( because i wanted to be sure that the printer is not getting some weird signalls from the PC)
But in general the issue seems to be the same!
Hi,Can you print test models successfully?SackofFluor wrote: Thu Mar 26, 2020 6:42 pm Hi William,
SackofFluor
Can i download a test print somewhere here in the forum?
EDIT:
I found the SD card with the test models, the first layer again looks really really good, then, when it comes to the walls of the 2nd layer it crashes....
EDIT:
Hi, can you provide picture?SackofFluor wrote: Thu Mar 26, 2020 7:09 pm Can i download a test print somewhere here in the forum?
EDIT:
if so, the motherboard chip maybe is broken.
SackofFluor
I wanted to make a picture, but this time, he didnt even make it to start the print, it was still busy doing the Extruder warm-up :/
If that broken motherboard chip is correct, where can i get a replacement part?
Sincerely
Sack
Sincerely
Sack
Hi, If there is a problem with the chip on the motherboard,
You can contact your sales description,
Or provide a platform for the printer you purchased,
Order number, country and email address.
I will pass it to the relevant colleagues.
SackofFluor
Hey William,
bought it in March 2019 via Amazon in Germany. Dont have the exact order number anymore.
Sincerely
Max
Sincerely
Max
