Horizontal "pits" are repeated on the 3D model (maybe not a wobbling)
wazls
Post by wazls »
On any model there are such "pits", how to solve this problem?
Note:
  • the 3D model's fan does not work (broken)
  • PLA plastic (temperature: nozzle-210, bed-55)
  • nozzle 0.4
  • slicer Cura 4.5
Thanks!
Re: Horizontal "pits" are repeated on the 3D model (maybe not a wobbling)
Hi, You can check whether the lower z-axis threaded rod is bent or caused by missing teeth,
Check whether the mechanism is loose and fasten it.
wazls
Post by wazls »
I printed out and installed this model while there are no deep pits. Apparently the Z axis isn't exactly perpendicular
you can check whether the Z-axis threaded rod shakes.
If the fan is damaged, you can lower the temperature appropriately.
wazls
Post by wazls »
Just a little bit, minimal backlash to the left and right. I think this is not critical. So far the problem seems to be fixed, I hope for a long time.
