Changing Filament on A20T
WinnieTheWoo
Post by WinnieTheWoo »
Hi Forum,
how do I change the filament for all 3 nozzles, not just E1. E1 is the only nozzle showing on the menu and doesn't toggle.
Kind regards,
The Woo
Re: Changing Filament on A20T
Hi, you can select "Mixer" and press the knob.
Turn the button to select "Mix: 100; 0; 0%", adjust the mixing ratio, and press the knob to confirm the setting.
"Toggle mix": quickly reverse the ratio between E0, E1, E2
Hope to help you.
