A10 Fine Tune setting...
div3boy
Post by div3boy »
Newbie here, starting to get use to the machine after tons of reading and videos. Just a couple of things, I did a search on this forum but didn't really find a solution...
1. When setting the speed, bed temp and nozzle temp in the Fine Tune settings, does this over ride what was set in Cura? If so, how do I reset it to go back to using the Cura set speed and temps automatically after I hit print?
2. Also, I read that the print table dimensions in Cura for the A10 printer is not accurate. When I changed it in Geeetech A10 Machine Settings in Cura, it reverts back to the default. The Printhead settings on the right for XYZ have numbers in them, aren't they suppose to be all zeros?
* Sorry for asking dumb questions, my first 3D printer and learning lots and as I go. Great thing to have during these times, stay safe all!
Re: A10 Fine Tune setting...
Hi, you can use cura configuration file, you don't need to reset it when printing for the second time. Click "Import", select the following file and save it.
Sorry for your second question, I did n’t understand it. Can you describe it in detail?
