I am experiencing problems updating (re-flashing) Marlin FW to my A10M on a Macintosh.My latest attempt resulted in the Hotend moving too far to the right by about 50mm when I initiate a bed leveling with the control panel. Also, when I execute a print command, using Simplify 3D, the movements work fine, but after the nozzle and bed heat, the printer freezes and disconnects from my computer (everything seems to stay running on the printer).
I am attaching a copy of my Marlin code if that will assist in getting me on the right path. Thanks for any help that you can offer.
Help with updating Marlin 2.0.x
- Archive.zip
- (67.04 KiB) Downloaded 350 times
Re: Help with updating Marlin 2.0.x
Hi,We have not tested marlin2.0, it is recommended that you use 1.1.8
