Magnetic Hotbed
Magnetic Hotbed
Hi can anyone tell me if there is a magnetic hotbed available for the A20T as I have great difficulty removing models from the heated bed after completion, I have the reheat the heated bed and then it is a real struggle to remove the model it is so hard that I am afraid that I am going to damage the printer. I had a similar problem with my Creality CR-X and a magnetic bed cured the problem but I can't find one to fit the A20T.
Re: Magnetic Hotbed
Hi,You can try Mylar with magnetic plate.
Or increase the number of underlying layers
Re: Magnetic Hotbed
Hi,Stevo61 wrote: Mon Mar 23, 2020 5:01 am Hi can anyone tell me if there is a magnetic hotbed available for the A20T as I have great difficulty removing models from the heated bed after completion, I have the reheat the heated bed and then it is a real struggle to remove the model it is so hard that I am afraid that I am going to damage the printer. I had a similar problem with my Creality CR-X and a magnetic bed cured the problem but I can't find one to fit the A20T.
I have the same issue. Removing the items is a nightmare.
Did you find a magnetic bed that fits?
Cheers
Oli
Re: Magnetic Hotbed
I am having the same problem and am considering returning the printer as it is almost unusable
andrevanderweide
Re: Magnetic Hotbed
by one to big from creality and cut it a little works perfect
grt André
grt André
Creality Ender 3v2
Creality S10 Pro Marlin 2.0
Re: Magnetic Hotbed
how about getting 2 magnetic covers for the bed glue one down on the hot bed with the correct polarity so to attract the other then you can do the same without buying a new magnetic heated bed or am I being dense and not understanding the problem
Re: Magnetic Hotbed
Since my last post I bought a Ziflex magnetic bed. It costs 49€ (including postage to EU) and it's basically what you describe. It's two plates both made of a magnet that attract each other. One is glued on the printer bed, the other goes on the top.Ade O wrote: Tue Apr 21, 2020 11:15 am how about getting 2 magnetic covers for the bed glue one down on the hot bed with the correct polarity so to attract the other then you can do the same without buying a new magnetic heated bed or am I being dense and not understanding the problem
The print sticks very well during printing and is extremely easy to remove. I clean it with washing up liquid and water. I have it only for 5 days but so far so good.
Re: Magnetic Hotbed
oh nice ill have to get one I have to take a sharpened scraper and pap it with something to get them off mine sometimes and I don't think its good for it I don't know why I haven't done it already doh
Re: Magnetic Hotbed
go to Amazon and search the ean Code 0738678973325
BCZAMD 3D printing construction plate steel spring plate bed 260x260 mm (10,2x10,2 inch) steel plate with PEI + magnetic sticker B surface printing incubators for GEEETE A20, A20M, A20, Tronxy X5SA
this is the magnetic plate i use. very easy to attach, very good adhesion and easy removal of the printed parts.
Best Regards,
Michael
Best Regards,
Michael
Re: Magnetic Hotbed
Use Geeetech SuperPlate and you will get out all problems with sticking.
A10 Slic3r profile: here
