Guide on proper filament replacement
eddyuk
Post by eddyuk »
Is there a guide on how to properly remove filament and insert filament on 3 nozziles? I always endup unclogging the hotend in the way I do it so wonder if I do it wrong.
Re: Guide on proper filament replacement
eddyuk
Post by eddyuk »
Thanks for answer, but it is cleaning procedure. I am actually referring to guide on loading and unloading filament.
Hi,it is recommended that you try to clean the hot end every time you run out
Barmac
Post by Barmac »
There has to be a better way.
You can't really expect people to do that every time they change filament.
How about switching to Teflon tubing?
You can let the three extruders discharge before printing, and then start printing.
Our white tubes are made of Teflon, make sure they are inserted at the bottom
