Help needed.....
Nightsurfer2002
Help needed.....
Post by Nightsurfer2002 »
I'm new to 3d printing and have had my A10 for just over a week. At first everything was going great and prints were coming out fine, but lately they don't seem to be sticking on the 1st layer.
The PLA starts to lay down its initial layer but starts to lift when its changing direction.
I've setup the bed level using the 4 corners paper technique which worked the 1st time I got the printer but now its fail after fail.
I'm using cura to slice these prints and have marlin 2 firmware.
Re: Help needed.....
Hello, you can adjust the parameters on the slicing software to improve:
1. Increase the thickness of the first layer.
2. The printing speed of the first layer is too fast, lower it a bit.
3. Confirm whether the hot bed is heated to a sufficient temperature.
4. You can use physical methods to apply a layer of solid glue on the hot bed. :D
