A10M Bed hitting the printers Y axis switch really hard.
When I auto bed level the bed. it dosen't level it like it should too it. 'Pls look at the video' https://youtu.be/XvewuFwzRoo
- Przepka1985
- Contact:
Re: A10M Bed hitting the printers Y axis switch really hard.
You need to change x_bed_size 225
Y_bed_size 225
X_min -1 y_min -7
Upload and test it.
On verts marlin 2 bug fix you will get same issue.
Best regards
Pawel Rzepka
- Przepka1985
- Contact:
You need to use non stock firmware.
I will prefer to use original but got couple of problem with code. And geeetech not rush with upgrades or release source code.
