Heating plate doesn't work
Theemy45
Post by Theemy45 »
Hello everyone,
I received and installed my 3D printer I3 pro B. After the first use I realized that the heating plate did not rise in temperature. In the attached picture, it can be seen that, despite a set temperature of 100 ° C, the plate remains at 20 ° C.
I had already checked the connections between the board and the plate, all seems correct.
Maybe someone can help me here ?
Thanks,
bang
Re: Heating plate doesn't work
Post by bang »
Did you connect the heating cable to the right connector on the board?
Maybe you can attach a picture of your wiring.
Theemy45
Post by Theemy45 »
Actually I found the problem, and it was actually the wiring as you said.
Thank you for your assistance
mathygreen
Post by mathygreen »
i had the same problem a few years back and it actually was the wiring problem they were mixed up
