Printer not registering.
That Gamer 64
I just tried to turn on my printer and the lcd screen didn't light up. I thought this was weird, but the fans were running so it ha power. So I continued to see if my printer would connect to repeater host, and theres nothing. I then tried to see if my board would connect to Arduino. It didn't. Any body else hade this problem or did my g2s just die?
Re: Printer not registering.
Hi ,you can try to open the printer normally.
Measuring its output voltage,
Reconnect the screen cable,
Then check if there are three lights on the motherboard.
To make sure there is a problem with the motherboard.
Internal memory reset.
Dirty or damaged contacts.
Protective strips.
Ink cartridge is not inserted correctly.
Incorrect consumable installed.
Cartridge Protection enabled. .
myfordbenefits
Protective strips.
myfordbenefits
This article is really amazing. Thanks for the information, keep sharing this type of info.
getmyoffers capital one
doubleyourline
inidgoapply.com
getmyoffer.capitalone.com
doubleyourline
inidgoapply.com
