Squeeking A20M extruder drive
rabbann
Post by rabbann »
Hi, I have one of my A20M extruder gear drives making a squeaking/squealing noise when it is retracting. It still extrudes correctly, just very annoying. I will be upgrading these extruders soon, is there any fix in the meantime? Any special lubrication etc?
Lexan
Re: Squeeking A20M extruder drive
Post by Lexan »
in my case it were the steppers that makes a lot of vibrations.
it helps a bit to tighten the frame screws to the stepper holder and remove the filament sensors
davesatu
Post by davesatu »
Check the FAQ section here.
Geeetech advises to use a drop of oil in the centre top hole in such cases.
Had the same problem - used INOX spray lubricant (same as but better than WD40).
Others that should work are Silicon and PTFE sprays.
Martinindsey
Post by Martinindsey »
Does any of you know what is the most important part in your car? Let me tell you if your that car part is waste your car engine is demage in that time. I know you people can easily attract when i tell you some best oil filter wrench for harley davidson. Yes i am using it and it always safe me and my car, Go and must take filters from there.
Alex Hall
Post by Alex Hall »
Mobile apps can be used to increase customer loyalty because it allows businesses to communicate directly with their customers via In-app purchases, ads, promotions, and notifications sent to customers' phone via mobile apps. Visit the android app experts website to find out more about the services we offer.
Ankit86
Post by Ankit86 »
Yes, you can check out lubricators online. It will help you in fixing out the problems which you are facing as of now. I was also facing the same issue but now it's working well. Cheers, buddy!!
Ankit Kumar
Developer at best app development company i.e. Grey Chain Technology.
Nazia20
Post by Nazia20 »
You can check it online my friend when I don't find anything offline for my Interior designer Kolkata business i go for online sites as there I easily get all my required products and raw materials. I am damm sure you will get there!!
Jack02
Post by Jack02 »
Jack is an enthusiastic business agent, and in the wake of getting done with publicizing and arrangements, he transformed into a Flutter application engineer. He is working in flutter app development company in USA
