Hello everyone,
I have a GeeeTech A10 with the V4 2560 board. It's a full width electronics setup, unlike the older versions. This model also comes with a metal L bracket for the 3D Touch. The issue is there is NO information anywhere about the offsets of this bracket, nor are there any firmware available for the V4 board and 3D touch pre-compiled I did make this work already with the latest 2.0 marlin; but I was curious if myappvalley tutuapp tweakbox
measurements are correct for the probe offset. Anyone else got this board and measured it? -47, -9 is what I measured.
GeeeTech A10 v4 Board 3D Touch Questions??
KellanCarson
Re: GeeeTech A10 v4 Board 3D Touch Questions??
hi
i got the same setup
and i am looking for marlin 2.0
can you share your firmware
Hello!
I bought a Geeetech A10 in July 2020, my board version is GT2560 v4.0.
The firmware is v2.0, the hardware is v5.60. Marlin v1.1.8 from 2017-12-25.
Now I have bought the Geeetech 3Dtouch sensor and installed it.
Is there a special 3Dtouch version for the board (v4.0) and the printer?
I have now downloaded the version A10_G05_V11.8_2-3DTOUCH.HEX from your
website and flashed it.
The printer now reports as GT2560 v3.x.
Is that correct?
Please answer,
thank you
Best regards
hz_scotty
Is that correct?
Please answer,
thank you
Best regards
hz_scotty
