I had some problems in printing quality (pla) in the last 2 months, after quite an year printing perfectly. Now the only problem is under-extrusion.
1) printer starts to print very fragile objects in Z axis. Checking hotbed height, but not solved
2) cleaned the nozzle, problem not solved
3) ERROR BED-TEMP (nozzle at -17 degrees). Solved changing the nozzle.
4) maibe it could be old pla material, dryed it using radiator temperature for a week. Not solved
5) changed material with a new pla filament. Never solved problem
6) here there is the delirium: 2 weeks ago I tried to dismount the head for a check of the situation. Remounted it: ERROR BED-TEMP (nozzle at -17 degrees). 2 days of panic. Changed three different nozzles, but error remained. Finally printer re-started connecting in a better way the head connector. Problem never returned and 2/3 nozzles fonctionning perfectly. Don't ask why...
7) now material didn't grip on glass. Re-calibrated head. Print job started good but under-extrusion from second layer, until nozzle clogged every time and I must stop job.
8) I found that the spring of the gear of the filament extruder was no so hard. Dismounted head and solved perfectly remounting it
9) Tested the extrusion on 100mm test measuring distance on the filament near the head. Extruder pulled only half the distance that should be. Tested the voltage of extruder driver(TMC2100) via multimeter. Result is ok (1.1V) and under-extrusion remains.
10) Finally today, I dismounted the gear of the filament-extruder. Cleaned, but it seems a bit worn-out. I'd like to change it, but I never had idea where to order it. For d200 on Geeetech shop here, I never find it.
Any other suggestion?
Thanks mostly to William for the help until now
Alan
great printer, but some troubles
- alan.guerzoni
Re: great printer, but some troubles
FOUND SOLUTION!!!
It was bowden cable, maibe occluded of PLA powder of one year intense use!
I remove it and tried to do a printing job. All returned perfect.
In this moment printer is without bowden, and it will be replaced with a brand new "larger" one in a few days
Thanks to all
Alan
Thanks to all
Alan
- alan.guerzoni
Not solved yet!
Probably found a new extruder gear:
https://www.ebay.it/itm/E3D-Titan-Extru ... SwiYlZ~Ebn
Contacting the seller to know the compatibility
- alan.guerzoni
Substitued the gear of extruder.
PROBLEM SOLVED!!!
If you have this problem you need a Titan Gear Extruder that is compatible
Now the printer is perfect!!
Alan
PROBLEM SOLVED!!!
Alan
sophiadevon189
ERROR BED TEMP nozzle at -17 degrees.Solved changing the nozzle.
