Geeetech 3D Wifi Module For 3D app does not work
I can not connect to WiFi the Geeetech 3D Wifi Module For 3D!
the GEEETECH A10M printer is connected to the box and recognized by the application.
the 3D WIFI connects to the phone's IP address 192.168.4.2 wifi.
Then the WIFI connection fails on my account FREE impossible to connect?
I tried on 3 different phones in WIFI 2.4 GHz without success.
The router detects the 3DWIFI on the IP address.
thank you for proposing me a solution
cordially
cordially
Re: Geeetech 3D Wifi Module For 3D app does not work
You can refer to this: https://www.youtube.com/watch?v=FguzMjI ... e=youtu.be
thanks for the video,
i did exactly as on the video and i am still in check when i
write my internet access on freebox rejection of the connection despite everything is right!
a +
a +
jenniferaniston
- Contact:
Use a pin to press and hold the hole marked "set" until the Wi-Fi indicator dims and flashes quickly. Loosen the overhead nails and 3D Wi-Fi will enter the configuration mode. Source: pay for essay by UK Writing experts.
Connect your 3D printer to the USB port of 3D WiFi Module with your USBvap38 wrote: Thu Oct 17, 2019 3:00 pm Hello,
thank you for proposing me a solution Great Lakes Login
cordially
cable for data transmission. Use the power cable to connect 3D WiFi Module with your
adapter to power it up.
Please check if the three indicator lights are on: Wi-Fi, USB, Power source from
left to right orderly. Insert the TF card into the slot
Long press the hole labeled with “set”with a pin, until the Wi-Fi light turns dim
and flickers quickly. Loosen the pin and 3D Wi-Fi will enter the config mode.
Note: If you do not loosen the pin, the light will flicker slowly to enter the reset mode.
Happy Adventure’s dune buggy Dubai tours furnish you with a novel chance to find the Dubai desert under the direction of our experienced and expert tour guides. Since our buggies are equipped with cutting edge security highlights,
Jasminmark
In the heat of the moment, it is easy for any student to make mistakes. However, if these mistakes are held onto, then they can drill boreholes in your academic performance. In such a case, students should make it a point to make use of the best online assignment writers, which is Crowd Content.
Thank you for allowing us to make backlink here. Drunk Uno
kanewilliamson23
If you have the Geeetech WiFi Module for 3D app installed, but the Geeetech Wifi App does not work, the problem may be that you are not able to use it. Firstly, you must ensure that your printer is within the range of your router. Secondly, you must have the correct password and name for the wireless connection, as well as the baud rate. Last but not the least, you must make sure that your printer has the correct power supply. The recommended power supply is 5V DC, 150mA average current and 500mA peak current. https://www.savinggain.com/view/zero-breeze
