Re: Hörprobleme - Gefühl von Wasser im Ohr
What's the difference between GT5 and GT9S assembled hotends?
watson
They are mainly diffrent in the construction of hot end.
Can you just buy the better extruder and upgrade the firmware without buying a Pro B? Assuming that you already have the regular Pro.zhangxueyou wrote:They are mainly diffrent in the construction of hot end.
Of course if you can.nagromlt wrote:Can you just buy the better extruder and upgrade the firmware without buying a Pro B? Assuming that you already have the regular Pro.zhangxueyou wrote:They are mainly diffrent in the construction of hot end.
Is it as simple as replacing the part and updating the firmware? That would be simple for me.
Having to readjust/configure voltages and Amps would be not so simple... but still doable.
Is there documentation provided by GT on how to do this?
Just replace the part and upgrade the firmware, I think.
