Hi.
I plugged the card to your point wi-fi, and lost control of the Shield.
I tried to use the instructions on the recovery Shield but did not begin to identify.
http://www.geeetech.com/wiki/index.php/ ... Yun_Shield
>How to recover the Iduino_Yun_Shield in case firmware crash?
I install:
dragino2-yun-common-v2.0.3-kernel.bin
and
dragino2-yun-common-v2.0.2-kernel.bin
and
ms14-arduino-yun-kernel-v1.3.3.bin
and
ms14-arduino-yun-rootfs-squashfs-RC1.2.bin
Firmware took here:
http://www.dragino.com/downloads/index. ... mware/Yun/
U-Boot 1.1.4 (Jun 3 2014) - load properly
Factory firmware has been:
Firmware Version: Iduino-V1 geeetech-2.0.2
Build Time: Wed Jan 14 17:10:01 CST 2015
None of these firmware did not help launch WiFi Shield. What should I do? where to find the original firmware that would reset everything to factory settings?
Please help me.
iduino yun wifi shield
hellogen-klg
Re: iduino yun wifi shield
I have trouble too, but in my yun doesn,t work lan. I can,t firmwire it. Device blinks leds, but can,t upgrade. LocaMy pc don,t look the yun shield over rj45.
And 3.3 v don,t work too
I entered a wrong router WiFi password and now I cannot access the yun shield any longer. How can I reset the iduino yun WiFi?
Thank you!
Jesús
Thank you!
Jesús
zhangxueyou
Hi, jgabjgab wrote:Hi,
Thank you!
Jesús
Keep pressing "reset" button on yun shield, release the button after 30 seconds.
Thank you, it works...!!
catttdaddy
I have the same problem where my Iduino will not connect to network and I see no WiFi to connect to. I have done both the 5 and 30 second resets. Anything else that can help is appreciated.
