Heat Bed and LCD Issues
Xadamx1
Re: Heat Bed and LCD Issues
Post by Xadamx1 »
I reuploaded the firmware, and still no change, the x-stop does not work and the LCD still displays the same, the heatbed is still out of control.
Xadamx1
Post by Xadamx1 »
I reburned the firmware, no change in the LCD, x-axis, or heatbed. But know the Y-axis constantly steps back towards the y stop.
zhangxueyou
Post by zhangxueyou »
I can see you wire the y motor wrongly in the picture you post. Are you sure the motors and LCD are wired correctly?
Xadamx1
Post by Xadamx1 »
The y axis performed fine before the reburn, I don't believe the connection is the problem. In any case here are pictures of the LCD connection on both ends as well as the y axis to the board. http://m.imgur.com/a/zbwrH
zhangxueyou
Connection is correct. Do you use our firmware ?
Xadamx1
Post by Xadamx1 »
Yes, I used the firmware you sent me.
Xadamx1
Post by Xadamx1 »
zhangxueyou
Sorry, I forget your email ,could you please tell me again? I want to check the firmware.
When you swap the connection of 2 cables of LCD, what is different?
Xadamx1
Post by Xadamx1 »
My email is aphlipot159@gmail.com. When I swap the cables for the LCD the display just goes blank and stays that way.
Xadamx1
Post by Xadamx1 »
Just uploaded the firmware I was just sent, no change, in the LCD, x-end stop, or heat bed. But the Y- axis has stopped doing it's random stepping.
