Delta 3D Printer
emeraldmeadows
Delta 3D Printer
Is the delta 3d printer better than the Cartesian 3d printer. Can I use the same STL files with the delta 3d printer as with the regular 3d printer.?
Re: Delta 3D Printer
yes,you could use the stl files,but you should set up the printer type from class Classic printer to delta rostock mini in retetier host.emeraldmeadows wrote:Is the delta 3d printer better than the Cartesian 3d printer. Can I use the same STL files with the delta 3d printer as with the regular 3d printer.?
