X,Y,Z AXIS GRONS SIDE AND THE EXTRUDER MOTOR DONT WORK
azaquy
Post by azaquy »
i have a delta restock mini g2 but wen i tred to move the axis with the repier the axis move in the oposite side, and wen i use the lcd to move the axis its the seme.......for example i move x positive but the motors move in x negative........ans are the same with all the axis, and other problem that i have its with the extruder motor wen i tried to move with the repier this dont work, i change the motor and the driver to other axis to check ant its working fine
zhangxueyou
Re: X,Y,Z AXIS GRONS SIDE AND THE EXTRUDER MOTOR DONT WORK
Post by zhangxueyou »
How about re-uploading the firmware? The firmware has been sent to your email.
And you must raise the temperature to 180 degrees to move the extruder.
azaquy
Post by azaquy »
i resolve the problem but now i have more problems....no one of the fans are working after reinstall the firmware.....y check the conection and are fine, i check the voltage and i dont have any in the area of fans......other problem that i have its that when i made the autolevel, i put all the axis in the center but when i tried to move y and x in negative and positive this crash with the bed........i up the z axis 3mm and the axis dont crash......for example i put z in 3mm, in the center of the ber had this distance betwen the bed and the extruder, but when i go to z=3 x=-50 y=-50, the extruder are touching the bed and when i go to z=3 x =+50 and y= 50 its the same the extruder are touching the bed, and this are the same with the same dimencions in positive and negative, but when i go to all the axes in 0 its perfect the center and the extruder are in the exact position
Sherry
Post by Sherry »
please restart the firmware.
Sherry
Post by Sherry »
please restart the printer.
azaquy
Post by azaquy »
I did that already , and resets it and printer firmware but nothing, and check the output voltage and nothing
Sherry
Post by Sherry »
hi,you try to plug the fan connector to others fan slot.there are 3 fan slots on the board.
regarding to auto-leveling.please see the link.it will tell you how to auto leveling.
http://www.geeetech.com/wiki/index.php/ ... o-leveling
azaquy
Post by azaquy »
this are already make it....y put it the the fans in diferent slots but nothing, o check the voltage in the three slot fans but there are not any a voltage, about the leveling this are already fixit, only i have the problems with the fans
SteveShein
Post by SteveShein »
azaquy wrote:i resolve the problem but now i have more problems....no one of the fans are working after reinstall the firmware.....y check the conection and are fine, i check the voltage and i dont have any in the area of fans......other problem that i have its that when i made the autolevel, i put all the axis in the center but when i tried to move y and x in negative and positive this crash with the bed........i up the z axis 3mm and the axis dont crash......for example i put z in 3mm, in the center of the ber had this distance betwen the bed and the extruder, but when i go to z=3 x=-50 y=-50, the extruder are touching the bed and when i go to z=3 x =+50 and y= 50 its the same the extruder are touching the bed, and this are the same with the same dimencions in positive and negative, but when i go to all the axes in 0 its perfect the center and the extruder are in the exact position
Can you please tell me what you changed to resolve the X axis moving in the wrong direction? I have this as well, and if I can get something to print (still trying to calibrate and getting terrible quality), the model is always mirrored.
