G2s compatible Jhead list
Buzz
Re: G2s compatible Jhead list
Post by Buzz »
I do not have PLA now which I will order. What is the setting for ABS? Please reply to my earlier questions especially the vertical dimension accuracy. I can't print the plastic parts if there are inaccuracies. Sorry to keep bugging but I do need to get good after struggling more than 2 months before I can get it to print.
Buzz
Post by Buzz »
I printed 20 mm calibration cube. My measurement is below. X and Y is very accurate but Z (height) of cube printed is out by 0.13mm. The difference may look small but when I print higher or larger object e.g. 50mm cube, it will increase. Also, it may cause screw holes to be oval and not circular. Let me know how I can correct this. Thanks.
X - 20.02mm
Y - 20.02mm
Z= 19.87mm
Buzz
Post by Buzz »
This is my measurement
Buzz
Post by Buzz »
My Z offset is 1.10 from the LCD screen. Does it help changing this? I read about getting steps per mm right. Mine is supposed to be correct at 80 for x, y, and z axis. So do I set to 80.52 instead to get it right and re-calibrate the diagonal rod and delta radius? I set my diagonal rod to 200 instead of 186 which is what I measured. Thanks.
Mark
Post by Mark »
" Mine is supposed to be correct at 80 for x, y, and z axis. So do I set to 80.52 instead to get it right '
Have you tried 80.52? what's the result?
Buzz
Post by Buzz »
Not yet. I will try later this evening.
