Absolutely desperate
Re: Absolutely desperate
Seems like the J-head is melted...you can check the inside of the peek J-head, see melted or not.
No. The J Peek it's perfect. The stain that you see over the nozzle is black PLA. The problem, I think is that the nozzle is completely blind. There's no hole for extrude PLA so the filament needs to get out for anywhere.
Clean it up and do you see anything different?
After several cleanings and printing tries, I think I'm ready to give up...
I think you can take a picture of the "blind" hotend and contact the seller to replace it .
Message sender to the seller asking for reading this post.
THX Mark
THX Mark
I had , have same issues .. got new hot ends.. but still not able to get pla to stick to bed. homeing seems wrong & air print ...inconsistent not printing yet. even when set to bed moves up in air , do I need to reset steppers 1/16 or finer I don`t know why not tracking right. uneven level when moving y x moves up will not print or move level.
god ...so many problems...what's your printer type, maybe you can give us some details or some videos to help you.
g2s lol you? I have to say I am having fun banging my head. I have seen this work..video. but It should work. Issues too some degree are experience, advice & information.
Homing & setting should have these issues listed & fixes ready. documentation needs an update. more info on setting & setup for 1st print, may-be a g-code item o test print 1st time. Help us noobs asap
got the g29 command working... need to do some tweeking in config.h. Make sure print end stop is on 1 & 2.... test then try g29 a fee times. I still have issues but got this far...lol now the next issue.
