MMA7361 accelerometer
vangarini1
Post by vangarini1 »
hello,
when i use the arduino 1.0
and AcceleroMMA7361
all these erros shows up
can you all help me?
G_Force:32: error: redefinition of 'AcceleroMMA7361 accelero'
G_Force:2: error: 'AcceleroMMA7361 accelero' previously declared here
G_Force:33: error: conflicting declaration 'double x'
G_Force:3: error: 'x' has a previous declaration as 'int x'
G_Force:34: error: conflicting declaration 'double y'
G_Force:4: error: 'y' has a previous declaration as 'int y'
G_Force:35: error: conflicting declaration 'double z'
G_Force:5: error: 'z' has a previous declaration as 'int z'
G_Force.cpp: In function 'void setup()':
G_Force:37: error: redefinition of 'void setup()'
G_Force:7: error: 'void setup()' previously defined here
G_Force.cpp: In function 'void loop()':
G_Force:42: error: redefinition of 'void loop()'
G_Force:16: error: 'void loop()' previously defined here
techsupport
Re: MMA7361 accelerometer
Post by techsupport »
Hi friend,
Have you dragged other examples of MMA7361 into your IDE and compile them together? If you did, it would cause such problem.
Regards;
techsupport
Email: forum@geeetech.com
