M201 firmware - supported GCODE command list
stado65
Re: M201 firmware - supported GCODE command list
Post by stado65 »
Hi Mark,
Could you give us an ETA for the M201 firmware update taking into account (some of) our requests regarding GCode support ?
Mark
Post by Mark »
I just asked the engineer, might need you guys to wait for about two weeks, maybe the end of this month, hope you can understand.
stado65
Post by stado65 »
OK, thanks for your quick answer.
Mark
Post by Mark »
the firmware has been updated to V1.0.5, just added some gcode commands, the other ones will be added later:
M92: Set axis_steps_per_unit
M110: Set Current Line Number M500
M502: Revert to the default "factory settings."
M300: Play beep sound
M304: Set PID parameters - Bed
stado65
Post by stado65 »
Hi Mark,
Perfect !
Will try this ASAP
stado65
Post by stado65 »
The 1.0.5 firmware is a real improvement. The printer works flawlessly with Octopi now.
You did a great job, thx !
cerealkillers
Post by cerealkillers »
Is there any chance the PID tuning commands will be implemented?
M301 - Set PID values
M303 - PID tuning
M500 - Save
