Hi!
I hvae the pro C.
Previously, my fuse (LF15A) on the GT2560 burnt with it's holder. As a result, I couldn't get the heatbed to heat. I fixed it up by buying a few fuses online, and inserting them into the burnt holder.
Although it worked, for some reason it generated a lot of heat and burnt more fuses as a result of the resistance caused by the burnt fuse holder. So, I decided to remove the fuse holder and solder the fuse directly to the mainboard. As I removed the holder carefully, I noticed that there is no "metal sheet" I can solder the fuse to. See the pics below. What can be done so I can get the heatbed to work again?
Thanks.
(The previous post somehow deleted...)
Pic: http://i.imgur.com/vJnjFqc.jpg
Heatbed fuse circuit problems
ohad135123
Jump to
- Update Announcement/Product Release
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3/DIY Printer Series
- ↳ FAQ-Geeetech I3/DIY Printer series
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Configuration Profiles Sharing
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- ↳ Video about cleaning and replacing nozzles
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
