Faulty driver?
baw87
Faulty driver?
Post by baw87 »
Hi guys,
I have recently finished assembling my Geeetech Aluminium Prusa i3 as below.
https://www.amazon.co.uk/gp/product/B01 ... UTF8&psc=1
All went well. I have Repetier Host installed and connecting. When Trying to home the X and Y axis move nicely and home on the stops but...
The Z axis motors just shake and make a vibrating noise.
After looking online and seeing that some people have trouble with the threaded rods binding I removed both couplings to see if the motors would turn when they are disconnected from the threaded rods.
They still make the same noise. I have tried the motors plugged into to other driver boards and they both work. I have tried the other motors on the Z axis driver board and none of them work.
I have adjusted the driver V to see if this makes a difference but no. I think I am right in saying that the driver board is faulty?
I have ordered these to see if one of them fixes things. https://www.amazon.co.uk/gp/product/B01 ... UTF8&psc=1
I'm new to these printers but am fairly mechanically savvy.
Thanks in advance!
Ben
Re: Faulty driver?
baw87 wrote:Hi guys,
Thanks in advance!
Ben
Hi,Ben
Check it out by following the link shows:
Plus,if you swap the driver board of Z axis with X axis's and the Z motor works while X motor doesn't,maybe the driver of Z axis was broken...
