Prusa I3 X - Simplify3D Profile
jeremy450
Post by jeremy450 »
Hey There
Does anyone have a Simplify3D a profile for the Prusa I3 X?
regards
Jeremy
Re: Prusa I3 X - Simplify3D Profile
jeremy450 wrote:Hey There
regards
Jeremy
Why not try Repetier-Host?
syossi2
Post by syossi2 »
i use simplfy3d on my m201 works great !!!!!
printing 3D with M201 Geeetech
jeremy450
Post by jeremy450 »
Hi William
I'm using Repetier-Host? But I am having major issues with supports with slicer3d. Problems to the point where by the time you get the supports off you've destroyed print. All my research has found that there's major issues with supports with slicer3d and Repetier. So want to use simplify3d.
Regards
Jeremy
jeremy450 wrote:Hi William
Regards
Jeremy
Hi,Jeremy
I guess you mean the support material problem?Could you plz give me more details about it?
Best Regards
jeremy450
Post by jeremy450 »
Hi William
Sorry for the late reply didnt get the email that you replied to me. The problem i am having is when i use Repetier-Host the support material is extremely hard to remove to the point where you almost or in one case i had broken the print. Currently i am using Craftware's software and i dont have any major issues with the supports and find them very ease to remove the support material. But i would like to try and use Simplify 3D but i want to get all the correct settings, etc before i attempt to buy and install the software. As from everything i have seen Simplify 3D has the best slicer, etc out there.
regards
Jeremy
regards
Jeremy
Hi,Jeremy
Have you alrady seen this before?https://www.simplify3d.com/support/tuto ... tructures/
I should say,you only can get some reference from the user manual and learn what each setting means,cuz it doesn't fit every object you print if i give you a default config.How do you think ?
Regards
jeremy450
Post by jeremy450 »
Hey William
i already deal with Support modification with Craftware. They give you the ability to remove/add supports all you want. so far its been going well. Had a few issues but i am still changing it and supports a almost as good as simplify 3D.
it would help alot as reading manuals and see the actual settings are alot different and easier to see and understand.
regards
Jeremy
merlinorn
Post by merlinorn »
i'm looking for simpify 3d profile... my printer is geeetech aluminium prusa i3
