How to install the firmware for GT2560
Locked
pekkap100
Re: How to install the firmware for GT2560
Post by pekkap100 »
I've noticed that. Why can not I open a file of the same law? I wonder what am I doing wrong? Difficult for me;)
pekkap100
Post by pekkap100 »
I got it to work !! Now we just have to continue from where I started the motor reversible. Many thanks :D
Pekka
Alandac
Post by Alandac »
How long should the upload take? I Have a brand new Geeetech Prusa i3 pro B, and have followed these instructions, but the Arduino software seems to be freezing on the upload (now going on 10 minutes). I have previously communicated and printed via Repetier, so I know com is OK. I'm on Linux/Ubuntu 14.04, using Arduino 1.0.5.
Thanks for your help.
bang
Post by bang »
Alandac wrote:How long should the upload take? I Have a brand new Geeetech Prusa i3 pro B, and have followed these instructions, but the Arduino software seems to be freezing on the upload (now going on 10 minutes). I have previously communicated and printed via Repetier, so I know com is OK. I'm on Linux/Ubuntu 14.04, using Arduino 1.0.5.
Generally the procedure takes 2-3 mins on Windows.
Alandac
Post by Alandac »
Thanks Bang,
I did resolve the problem. The RepetierHost V1.6.0 was interfering with the communication between the Arduino IDE and the printer. I just closed the RepetierHost program, restarted the computer and the printer doing to a reset and then the upload took less than a minute.
Greetings and Happy new Year to all of you. :lol:
bang
Post by bang »
Congratulations and happy new year :lol:
pat51
Post by pat51 »
hello every body
I am a new user
axes mvts are wrong
I try to put a good firmware for Prusa I3 pro B
with Arduino when I try to transfer, I have this msg on Arduino
"error msg"
Arduino : 1.8.1 (Windows 7), Carte : "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
from sketch\BlinkM.cpp:5:
#define X_MAX_PIN -1
#define X_MAX_PIN 24
#define Y_MAX_PIN -1
#define Y_MAX_PIN 28
#define Z_MAX_PIN -1
#define Z_MAX_PIN 32
from sketch\ConfigurationStore.cpp:1:
from C:\Users\Jacques\Documents\Imprimante 3D\I3_pro_X\I3_pro_X\Marlin\Marlin.ino:33:
from sketch\MarlinSerial.cpp:23:
from sketch\cardreader.h:8,
struct fpos_t {
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
Can someone help me
Pat
bang
Post by bang »
pat51 wrote:hello every body
I am a new user
axes mvts are wrong
"error msg"
struct fpos_t {
exit status 1
Can someone help me
Pat
Hi,Pat
So did you try Arduino 1.0.1?
pat51
Post by pat51 »
I am a new user
axes mvts are wrong
"error msg"
struct fpos_t {
exit status 1
Can someone help me
Pat
Hi,Pat
Hello Bang
At the first, I have taken Arduino 1.8.1 still go to download 1.01 and see
pat51
Post by pat51 »
I am a new user
axes mvts are wrong
"error msg"
struct fpos_t {
exit status 1
Can someone help me
Pat
Hi,Pat
Re Hello bang
first I reinstall Arduino versus 1.01 as you said and no error msg as before
I take I3_pro_X firmware on the forum and then put inside with Arduino 1.01
no error msg
then launch "auto home"
but just X motor goes to it good position
during this mouvement I saw Y motor giving a little smal mvt and Z equal juste move a little
I tryed another firmware named Marlin-PI3_Pro_B and same result
just good mvt motor axe X , a very little mvt of Y and Z.....
In lcd screen, when you try manual mvt, something may be strange just see axe X an Y???? Is it normal???
regards
pat
Locked
