geeetech i3 part cooling fan connection
travis2017
Post by travis2017 »
hi all im printing up a shroud for a 40x40x10 3 wire brushless ball bearing fan for a parts cooler
to fit my geeetech i3 prob
wich fan port do i plug in to 1 / 2 or 3
and does it matter if its a 3 wire fan or a 2 wire fan
and is there a link to what i have to do for the firmware or is it all ready set up in the stock setting
thank you travis
Cup
Re: geeetech i3 part cooling fan connection
Post by Cup »
Fans 1/2/3 are common ones that have the solid speed,you need connect the fan to PWM_fan if you wanna control the speed.
phil135
Post by phil135 »
ok, is it enough to check it in Slic3r ? or something more to do ?
