Prusa I3 M201 - Z axis is pulled down before printing
Mila
Re: Prusa I3 M201 - Z axis is pulled down before printing
Post by Mila »
I don't get any erros, that's the problem, it transfers the firmware though the hyperlink terminal and the version stays the same.
The endstop works normally when homing the axis, the problem is only when I send the printing order, it homes (correctly, albeit a little higher) and then pulls the nozzle down, it will keep hitting the bed until I terminate it.
Mila
Post by Mila »
Is there any way I can get someone to look into that? I can't print with this printer as it is.
