Did you fix it?
Did you feel the retraction with your hand and check the direction of your extruder motor(maybe move upward always?) when that happened?
Geeetech Acrylique Reprap Prusa I3 Pro B filament retraction
stavros_gr
Re: Geeetech Acrylique Reprap Prusa I3 Pro B filament retrac
hi yeah i finally fix it....
probable i did something wrong with the 1st set up cause i delete the repetier and load it again and works.. but only if i have it with my lap top connected if i do save to sd card and try to print it make every second auto home...... not sure why ....
thank you for your respond
