Easy Print installation
Re: Easy Print installation
Hello All,
my buttons don't show either (Win 10) so I cannot use this Software as it is! I have uninstalled and reinstalled as well as changing the video card setting, nothing worked. Disappointed.....
Does this Software replace Repetier Host? Can I use that? Will it work??
What other Software could I use???
Paul
Paul
To Sove this issue i've modified the printer.ini file into x:\Program Files (x86)\Geeetech\Easy Print
change Com port and printer name
Hi All,
Some of the issues reported here are due to the fact that configuration and data files are written under "\Program Files (x86)\Geeetech\". This location requires Administrator rights for write access.
Best regards.
Best regards.
The problem with incomplete windows is not fixed. Windows 10 platform. Must the program delete.
Same problem for me after a fresh installation in Windows 10. I can't see the for lower buttons, just their top view pixel rows.DoubleK wrote:Here a sample, that the buttons below i can not see. Slicer have no function in my programm.
https://postimage.org/index.php?lang=german
Can anyone tell me why the Easy Print running so slow. Versus Repetier-host it is infinitely slow.
I have one note: When I am choosing slicing, the duration of this function is infinitely long, essentially it never ends. What kind of program is the Easy Print? Also window for Manual Control is incomplete.
Why does it insist on using com port 25?
Can you help me please how to change the COM port in Windows 10? Thanks
Can you tell me what you want to change it to? I then may be able to help
