Radial fan problem MeCeator2
Bushido77
Post by Bushido77 »
Hi , I have a new MeCreator 2 and I'm having trouble getting the radial fan working . The fan works fine but it doesn't turn on during a print, Even if I select fan always on in slic3r or using repeatier-host. Any suggestions would be appreciated,
Bushido77
Re: Radial fan problem MeCeator2
Post by Bushido77 »
All other functions work by sending Gcode directly to the printer, except fan.
I've removed the fan and tested it and also checked the connections
Hi,could you take video about the situation that fan don't work?I think the port of fan in the Extruder development board may need to be resoldered.
Bushido77
Post by Bushido77 »
No sense making a video. Its quite simple the Radial fan of which there is one, is not working. Do you have a schematic of the GT2560 Rev B so I can check it ?
I'm going to send this printer back for a refund ,
radial fan.jpg (40.29 KiB) Viewed 6708 times
