Hi can some help please
My X axis works fine when I use the LCD screen to move it to the centre of the build platform
How do I set it to print in the middle of the build platform. At the moment it travels to the far right (200mm) and to the extreme front
I have manually moved it 100 to centre then set off sets and saved but it is not changing.
this is one problem to solve and I will only fix one at a time new to this.
Thanks Jim
						X Axis problem
Re: X Axis problem
There is one way to solve the problem via Repetier-Host,you click the configuration in the menu bar,and then choose the printer setting,next click the printer shape where you can find the hotbed left and hotbed front,these setting can help you printing in the middle of the build platform.
Re: X Axis problem
Thanks William
Finally after fixing minor adjustments to the printer after a new build I have it working properly.
Thanks for your help in positioning the build platform.
Jim
Jim
